Can anyone give me any tips on EQing? Links would be good. As a newbie there's a lot of info out there, so I just wondered what had worked for other people.
The #1 tip is that any other tips are extremely situation-specific, and that there are no general recipes that work in a majority of situations.
Think of it like this, Matt: Asking for tips on EQing is exactly like asking for tips on using spices in cooking. You'll wind up with an entire bookcase full of cook books and recipes, none of which will precisely apply to whatever your situation is at hand. All you can do is taste what's in the pan and figure out what it needs more of or less of by taste.
In audio, what that requires is learning what the various frequencies "taste" like; i.e. what they actually sound like. Only by being able to recognize the sounds of the different frequencies and their effect on the overall sound of your tracks can you taste what's in your mix and decide what EQ, if any, is needed to add to or subtract from what you have in front of you.
Grab a graphic EQ of at least 12-15 bands and several quality commercial CDs of varying music genres. Set the EQ to flat (all sliders in the middle). Sit down in front of your system and listen to this music played through the equalizer, moving one slider at a time up and down *slowly*. Return that slider to zero and move to the next one, and od the same thing all over. And so on down the line of EQ bands.
As you do this, listen *closely* to what each band sounds like, and how boosting it or cutting it affects each component of each instrument or vocal on the CD. What does this slider to to the clang of the cymbal vs. it's shimmering decay, which ones make the bass sound smoother vs. which ones make it punchier, how the different ones have different effects on the guitars or vocals, etc. I mean REALLY listen.
Do this for an hour or so a night for a week or two, memorizing both the effects of each EQ band and the frequency value each one controls, and at the end of that period you'll be ready to start making some useful sense out of the Interactive Frequency Chart located on the
Independent Recording Network website.
G.
