EQ - What can I hear?
  • Thread starter Thread starter DarkFriend
D
DarkFriend
What is the "normal" range of EQ for the human ear? When I'm mixing separate tracks, should I be cutting out any sound above or below that spectrum?
20-20khz is the commonly quoted range of human hearing. Adults lose the high range pretty drastically, most men probably can't hear much past 16khz. I wouldn't worry about low passing, but on the low end, subsonic frequencies will eat your headroom. Set up a high pass on pretty much everything, and adust the frequency higher until you can hear it start to work, then back it off until you can't.
You should be able to hear well down to 40hz, and you should feel / sense anything below that. Probably anything above 15-16 khz would be pretty iffy, alghough artifacts and abnormalities from that region can certainly have perceivable effects within the audible range.
Stupid question? If I'm setting up a high pass filter, should it be on the whole mix or each separate track?
