Fancy
pickle tanker
This is raw, without effects at this point. I'll be adding vocals next but I'd like to fine tune the instumental before moving forward. Don't hold back.
www.soundclick.com/katefancy
It sounds decent enough as it is at the moment and if I were you I wouldn't be overly concerned with fine tuning it until you have recorded all of your tracks and then you can determine what it may or may not need to make it fit the mix.Fancy said:This is raw, without effects at this point. I'll be adding vocals next but I'd like to fine tune the instumental before moving forward. Don't hold back.
Yeah, you're right. Thanks!Rokket said:The only thing I can see is that your drums are out in front of everything. The kick is drowning out the bass.
It sounds interesting. I can't wait to hear it with the vocals.
No problem!Fancy said:Yeah, you're right. Thanks!
My future mix suggestions will include a disclaimer that I assume no responsibility for exploding monitor speakers, hearing or pet loss that may occur, hah.Fancy said:I just finished applying Timothy Lawler's tips, and it was much improved, and I was about to start working on the others' suggestions. Then I had a major audio accident. I blew up the high end on both monitor speakers, my eardrums, and I think all the hair fell off my cat.
