mm2k5,
Ok, Right now in the rack we have 2 amps and now the newly bought EQ. Its a peavey that has the feedback finder. We are just using one amp for the moment....and we are bridging it and daisy chaining the 2 speakers we have.
IF this is the setup you have on your PA right now, you're not running stereo - a bridged amp runs mono - regardless of whether you have left/right inputs or a single source. If your speakers are daisy-chained from the bridged amp - you are definitely NOT running in stereo.
BTW - you cannot really run your EQ as an insert effect... it should be between the board and the amp(s).
Here's what I would do.... come out of the board (this is based on the Peavey RQ2300 series mixers) using the mono output. This is basically just a summed left/right output, but in mono. Run that signal line into your new EQ (you didn't say what kind). From the EQ run into your bridged amp input. Check the amp manual, but it should accept a single line in.
If you can provide more equipment details, (make, model) for the EQ, amps (wattage and impedance) and speakers (wattage and impedance), I can give you more detailed setup info (email me)
A word [or two] of caution....
PA-101 class here !!
make sure your bridged amp output impedance matches your speaker impedance. ???? Since your speakers are daisy chained off a bridged ouput, you need to know both the amp output wattage/impedance and your speaker impedance/wattage,a nd whether they are chained in parallel or series. I ask becasue more speakers are blown because of UNDER-powered or OVER-driven amps than any other reason.
Example. (this gets complicated AND technical, so be patient pls.)
Say you have 2, 8 Ohm speakers (say 300w RMS, 600w peak) daisy-chained. If parallel'd, the total impedance back at the amp is 8 + 8 = 16 ohms. If series, it is (8 + 8)/2 = 8 ohms.
Lets also say your bridged amp puts out 200w @ 16 ohms, 400w @ 8 ohms, 600w @ 4 ohms and 750w @ 2 Ohms.
Then, for the speakers in parallel, you are only putting a maximum of 200w into 2 speakers rated at 300w each. In series, you are putting 400w into 2 speakers rated at 300w each. The latter of these two is the better.
Look at it this way. .... you have 2 speakers at 300 watts each - 8 ohms. Wired in series you have 8 ohms and 600w (combined). In parallel, 16 ohms, 600 w. You will need an amp that will put out somewhere close to 600w bridged at either 8 or 16 ohms impedance to ensure you don't under power your speakers.
Check the clip light on your amp when you play... if it flashes (even occasionally), your amp is being over driven, and does not have enough power for the connected speakers. When your amp clips, it basically shuts it self off - momentarily. This in turn causes the AC signal being sent to the speaker to change to DC - momentarily. Think of the hot plate on your oven. DC signal to speakers basically acts like turning on a hot plate. It causes the the coils to overheat, melts the seals and ka-bloom. Blown speakers.
Once you understand the basics, it's not really that complicated.
Hope this didn't confuse you too much.
Regards,
Steve
