Was wondering which order members tweek their eq when mixing......Bass first,last ,in the middle, etc.......and advantages of each if any......I seem to mostly do it helter skelter,which I'm sure wastes time.......
I have 3-BAND eq on each channel, and only the mid is parametric. So I usually narrow the Q on the mid, crank it up to +16db and sweep through the bass first, for no particular reason. Once I find where I need to cut, I go up to the highs and see what's annoying up there. Then I do the mids.
getting a control on the low end i find is usually the best place to start....i throw on all my high-pass filters 1st, then get the relationship between the instruments that reside in the low end(kick, bass, etc.) worked out
after that, i just hit whatever sounds like it needs tweaking
