P
progmr
Can anyone please give confirm if my understanding of a 4-band parametric EQ is correct.
From what I have read it appears that it permits one to select a frequency (in this case up to 4) and either boost or decrease the gain on it and those close to it (depending on the envelope spacing?).
Now my question is:
I am trying to EQ a 12 string guitar who's middle B is extremely overpowering. If my assumption is correct my 4 bands should be between 82 (low E) and about 1045 (high C) and I can decrease the gain of a band at 246hz with a tight envelope to remove the offending note. Is this correct? Going forward in my understanding is it logical to assume that I need only set the EQ freqencies for range of the instrument I am trying to modify? What happens to those frequencies (assuming my 12 string situation above) that are not covered by envelopes set, are they assumed to be zero? My machine goes up over 2500 HZ which is out of frequency range for the guitar...so can I assume that I would never use this high of a setting?
Thank you in advance.
Now my question is:
