J
jimminy
Does anyone know a method that will allow me to transpose a note-on message, say from C1 to C#1, by pressing a sustain pedal or some other controller?
Here's why:
I have an older electronic drum set, tyically used with a real hihat, so it does't have any way to use a footswitch to change from a closet hat to an open hat. I don't use the drum module for the actual sounds because its so bad sounding, so it just sends the midi data to the computer and a drum machine. I have a pad programed to play a hihat, but I have to switch manually to get an open hihat sound to trigger.
I was thinking I could have the sustain pedal from my keyboard sending on-off data, and by some method or other have that cause the note to be transposed up to a different note and different sound. The effect would be to have the sustain pedal pressed when I want a closed hat (C1), and when I let off with my foot, have an open hat sound(C#1).
I've seen ways to do similar things but not this. help.
Here's why:
