longsoughtfor
Searching for the sound
Fredric - with you mentioning that you were a licensed electrician, this may be for you but any and all are welcome to help...
I just had the town building inspector in to check the framing and insulation of my studio. It is in my basement and so, none of the walls are load bearing. The inspector was done in about 3 minutes... the conversation went like this: Everything here looks OK, just get the electrical sign off before too long.
I have installed several outlets and ceiling light boxes as well as a couple of switches. I just read that the NEC requires outlets within 12 feet of each other and that any wall greater then 2ft wide must have an outlet in it.
Since I am building several walls with just a cloth face, I am hesitant to put outlets in those walls. See the attached diagram for outlet locations (they are the orange circles with two lines through them).
I also noticed that the NEC stated that basements required only one outlet.
My question is: From your experience, how do inspectors treat finished basements with regard to outlet spacing/count?
Thanks
Kevin.
Thanks
Kevin.
But thats me.
