Effects on one section
mcmac74
Active member
Hi
Its been a year since I did any recording after a hand injury so trying to remember half the stuff on reaper I never learnt properly in the first place 🥴...one of which is applying an effect to just one portion of the song ...a rejig of my memory would be helpful.
Cheers
Mark
You should still be able to use an envelope to automate the effect.
Note that certain effects work better on an effects bus. If you want to stop a reverb but let it decay, you need to cut the send rather than the output.
Just automate the 'wet' control of the fx plugin. I've done it to add a delay, a spot-EQ 'band-aid' and more.
Thanks for all the examples...this is probably as simple as I need it...seems to be same method as using volume envelopes. Perfect 👌
