Well, it's goofy as hell for a number of reasons. The most annoying thing is that n-track doesn't always seem to grab parameter names correctly, or in the right order.
Anyhow, when you click the envelope tool you can select effect automation (it's the last option). This will bring up a window where you can select an effect and a parameter (remember I warned you that it might not get parameters right so you have to guess sometimes). Then you can draw your envelope like you would a volume envelope...except that you can't do slopes, just jagged steps
To actually hear the automation, you have to make sure that the "P" button on the main mixer is enabled. This will turn off every time you restart n-Track, be warned. I don't know why "P" has to be on to hear effect envelopes but not volume or panning...who knows.
Another way to do automation is to hit the "R" button in the main mixer. Everything you do while you're playing back will be recorded. Volume changes, effect parameter changes, everything. It's kind of handy except that it's hard to make good adjustments with a mouse in realtime. When you're done, make sure to turn "R" off otherwise you'll accidentally make a lot of work for yourself
I haven't tried this with any DX effects yet...supposedly they have to specifically support automation so it might not work with all of them. It should work with any VST effect on the other hand.
Good luck to you...and if you're using version 3.0, you might have to upgrade...when I tried effect automation with that first version it was a crashing nightmare.
Slackmaster 2000
