G
ggunn
Crystal Flavolian
Light said:Second of all, Weld-Wood will never work. It is an epoxy and will stick to your truss rod, making it inoperable. Don't do it.
Au contraire. My Les Paul's cracked neck was repaired in 1977 by the Weldwood method I have described, and is still going strong. It's been through several setups, and the truss rod is fine.
FWIW, Weldwood plastic resin glue is water soluble. Although Weldwood makes epoxies, this isn't one of them.
I like your method of clamping with strips of rubber, though. How do you keep the glue that gets squeezed out by the clamping from sticking to it?
