If stopping echo is your only goal (and you want to keep it cheap), then some thick blankets all around will do the trick. If you want proper sound absorption and a "dead" room, then using a decent-quality studio foam like 2-inch Auralex is ideal for that purpose.
Unless you plan on applying a fireproofing fabric to the blankets - I would advise you to avoid that approach - blankets hanging down around your walls is one hell of a fire hazzard - and they go up real fast.
The foams are an effective product - as are rigid fiberglass - 703 or 705.
If you hang rigid fiberglass a few inches off the walls (and below the ceiling) it will help with high frequency reflections as well as tame some of the mid and higher bass frequencies.
I would avoid a completely dead room if I were you - it's very annoying.
Be certain that whatever materials you use are properly fire retardant, including whatever cloths you might use to wrap the fiberglass with should you go that route.
