Steps I take to save songs.
I have used Pyro 2003 (it is still on my Dad's computer at his house on the other side of town)...I am now using Pyro 2004, but I think it worked about the same (as far as recording and saving at least) (2004 added an effect plugin and more features as far as volume control) ...anyway I will walk through the steps that I go through to record and save a song to wav or MP3 (this is in Pyro 2004)...I hope this is helpful (I know some of this will be stuff you already know, but I am trying to cover all my bases)...after choosing the record window, the program forces you write a name in the box before you can engage the record. I write a name and push "record", I then start the cassette player (which is pluged into the line-in of the computer), when the song is over I click on "stop"...I now have a visual representation of the song (the deal that resembles the picture of a heartbeat on a monitor, exept much denser)...I usually edit this file (like I described before), doing a fade-in and fade-out (this diminishes the obviousness (or suddeness) of the cassette hiss, for one thing) and EQ. THEN I click on "SAVE"...I am given the choice of saving a "project" or saving an "audio file"...I choose "audio file"...then a new window opens up showing a folder with files I have saved before (listed in aphebetical order)...the program will not allow me to overwrite (using the same name I chose when I set the program up to record) (I think Pyro 2003 will allow you to overwrite the initial file) so I usually use the same name but put a "2" after it...If, at this point, I simply push "save" (or it might be "ok") the file will be saved as a wav file...If I want it saved as an MP3 I have to click on an arrow below the box (which probably says "wav" and it drops down and shows that you can choose MP3, which opens another little window that gives you different choices as far as what size MP3 you want to create...after making a chose (and probably clicking on "save" or "ok") the file is saved into the folder that I initially opened when I very first chose "save" and "audio file"...When I do this the program goes through the motion of saving (with a rectangle box filling, going from white to blue)...after that I can click on "open" and find the file in that folder (I find that clearing out the initial file (the heartbeat looking thing) often will prevent confusion as to what file I am opening)...when you open an MP3 the program must turn it back into a wav file in order to see, hear, or edit it, but then you can once again save it as MP3 (I usually stay with wav files until I get to my final version, since wav is supposed to be better quality and the program has to turn an MP3 into wav to play or edit it anyway) (I delete any early versions of wav file when they are no longer needed because they are like 5-10 larger than an MP3)...I hope this has not been a waste of time as far as your problem...I really don't know what else to tell you...I am pretty much a technophobe myself and was pleasently surprised that I could use Pyro right off the bat...that is why I thought it just might need reinstalling. I would like to know if you solve your problem and I would be happy to try to answer any more questions...
