Ummmm...dobro, the fundamental Low E frequency on a guitar is much higer then 82Hz. More like 340Hz (estimate here). Your open A string is a 440Hz tone (fundamental), half that would be one octave lower of course (220Hz). But the Low E string is a forth below, so about an half of an octave, thus how I got the 340Hz estimate.
Anyway. From there, you guitar produces higher fundamentals then 988Hz too. Your open High E string is somewhere in the neighborhood of 2KHz fundamental. 12th fret High E is over 4KHz. 22nd fret on high E sting is somewhere around 6KHz...etc....
Now, we are only talking about the "fundamental" note, not overtones! First overtone is an octave higher then the fundamental. Second overtone is an octave and a fifth. Third is 2 ovtaves....etc....So, your first overtone on ANY note on a guitar will have a strong presence of the first overtone which is an octave higher. So, that open High E string is going to have a a lot of sonic information at around 4KHz.
Now, a nice guitar tone really needs the presence of at least the first 5 overtones. So, that open High E string is going to need to have frequencies that are over 8Hz to be present at mix. A more brighter and brilliant sounding tone can be achieved with frequencies even higher then that being presented to the listener.
On the lower end of things. The wood of the guitar will produce subharmonic content. Plus, if you are running it through an amp, the volume of the speakers is going to "excite" the walls in a typical room, which will produce it's own subharmonic content too. So, you really need frequencies down to about 100Hz on a guitar to keep the sound full. Not all recordings really need guitar subharmonics below the 340Hz fundamental of the open Low E string, but a lot does to some degree or another.
A good bet for electic guitar is that you could slope out stuff below around 90Hz, and stuff above around 12KHz and not effect the primary tone very much at all.
On acoustics, getting rid of the low end stuff is cool, but, I don't recommend removing ANY higher frequencies at all. Acoustics tend to have far more information in the overtones that are needed to make it sound realistic on tape. Any high eq cut, aside for fixing minor tonal problems, will really take away from the "prettiness" of an acoustic. If anything, I tend to add a little High Shelf eq to acoustics to accent those frequencies.
Ed
[This message has been edited by sonusman (edited 06-17-2000).]
