dumb question about Rhodes EP mark II
  • Thread starter Thread starter SheHadTheJack
SheHadTheJack
Hi
About the Rhodes Electric Piano Mark II. Where the H*** does the power go, i cannot find a power plug???
Sorry for the dumb question, hope some of you have this piano at home. I have searched the web for an answer, but since no one has found it strange enough to post on the net, maybe it is really obvious.
/Carsten
Yeah ..... the Rhodes uses pu'ps much like an electric guitar to produce sound. There was a Rjodes with a stand that contained speakers and an amp but the piano itself doesn't require power.
If you are in the market for a rhodes, there a several pre amps specifically designed for them which will bring the levels up to line, otherwise its a fairly quite output
Thanks for the answers. "works kinda like a guitar": i guess i could have somehow figured that out myself, since i had it opened and saw the "guitar-like" pick-ups. I just figured since the jack on the front said Input, that it would have to be some kind of effect/sustain thing.
But thanks. I`ll give it a try with my amplifier.
/Carsten
PS: I really cant stand when people write "dumb question about ... " instead of just "I have this exact problem ... " - are there anyway i can change the title of my thread?
Yeah, it does say input.
Now it's time to look for a phaser pedal for it - really cool. I have an old one I use with big volume and speed dials on either side. I really don't play it much these days after using NI's Elecrik Piano.
Uhm. Now you're confusing me. Should i plug the amplifier in the input jack?
Or is this really for effects... were you being ironic?
:confused:
Or is there a hidden jack output i just havent found?
/Carsten
PS: Warble2s wikipedia link is the exact same rhodes i have.
PPS: havent tried with amplifier yet, since i don't have the rhodes at home.
Sorry....I just re-read my post and understand how you would have taken it the way you did. ;)
Yes, that is the jack used to plug into an amp - it's the only one on that Rhodes.
I used that phaser pedal, but ran from the Rhodes jack to the pedal input, then used the pedal output to the amp.
