E
ecc83
Haha thanks about the questions,
The KA6 only has 2 XLR/Line in. If I read your post correctly you can also use the 3/4 Line In for Instruments. This would be 4 analogue inputs but only 2 can be used for microphones.
The Tascam has 4 XLR/Line in.
Now if I bought a mixer like
Yamaha MG10/2
and use all the inputs on that would the preamps on the KA6 work with the mixer? ( So if I connected 4 mics through the mixer they would all have gone through the pre amp of the KA6 ).
Yup, missed that! The 600 does have 4 mic pres but I still say that the Ka6 is a better AI overall.
The Yamaha mixer would be a fine addition IMHO. You would get the 4 mic channels you want plus two more you can pan in. (4 mics mixed to stereo could make a passing good job of a drum kit). The mic pre amps on the Yamaha are likely just as good as the Ka6, maybe a tad better. They will certainly have more gain.
Mixers seem to have gone out of fashion a bit in the home recording game but yes, the combination of the Ka6 and the Yamaha would be a very flexible and versatile one indeed.
Just noticed, sorry an operational error. No, you would not use the 4 mic inputs on the mixer for 4 channels. You would need to use the two on the KA6 then feed the mixer's output to lines 3&4 on the KA6 and use chans 1 and 2 on the Yammy but the other inputs on the mixer can be used as well, just that they will all appear on tracks 3 and 4 in the stereo "picture".
(actually there IS a way to use the 4 Yammy pres but tis a bit complicated. Let's K.I.S.S. for now?)
