<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by Slackmaster2K:
I read recently that Athlon chipset dual processor support is on hold and is not anticipated any time in the near future. I'll have to recheck that source.<HR></BLOCKQUOTE>
A dual-Athlon or symmetrical multi-processing (SMP) chipset is presently being designed by AMD and Alpha Processor Incorporated (API). The new chipset will come along fairly quickly because it will actually be just a subset of an existing Alpha chipset called "Tsunami." Of course, the Athlon is not an Alpha (RISC processor), so they will have to modify the interfaces to some extent, but most of the hard work has already been done. Target date for the Athlon SMP chipset is still "2H 2000" -- which really means sometime after 1/October.
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Note however that you're not going to see better disk performance because you have 4 PIII 1Ghz processors.<HR></BLOCKQUOTE>
What with processing power scaling upwards faster than everything else like RAM, I/O busses, storage channels, and mass storage, it seems now that there are all sorts of system bottlenecks.
Case in point:
The once "speedy" PCI bus (33.3MHz x 32bits wide = 133MB/s theoretical bandwidth) has now become THE bottleneck on higher-end systems. So how do you fix this problem? The first "fix" was to go to 2 (or more) PCI busses and segregate expansion cards in a way to reduce PCI bus saturation. There are only a few PC mobos available that have at least 2 PCI busses.
Here's one here:
http://www.supermicro.com/images/Imag_Prod/p6dgh.jpg
Chipsets that support multiple PCI busses are rather expensive. So, the simplest solution to increase PCI throughput has been to increase the PCI bus clockspeed to 66MHz and the PCI bus width to 64-bits (66.6MHz x 64bits wide = 533MB/s theoretical bandwidth).
There are now finally a few PC mobos coming to market with these new 4x PCI busses. But, even this 4x speed-up of the PCI bus has proven not to be enough with everybody. There are some Compaq Alpha systems soon coming to market that can support up to
256 separate 66MHz/64-bit PCI busses!
There is another speed bump for PCI coming next year and there is an all-new expansion bus coming along as well. The next PCI will be called PCI-X and will be clocked at 133MHz (133MHz x 64bits wide = 1064MB/s theoretical bandwidth).
In 2002, InfiniBand will show up. Even though there will indeed be X86 systems using InfiniBand, just don't expect to see this bus in a typical PC any time soon, though. InfiniBand will have bandwidth starting off at just over a GB/s and can be scaled by adding "wires" to the bus for parallel operation. In fact, InfiniBand can replace PCI, SCSI, and Ethernet all at once! With InfiniBand, you can also design and build a "switched fabric" between devices so that you don't have bottlenecks anywhere, even with all of your devices going full bore.
In any case, PCI will still be around a long long time. Hopefully it will at least be able to keep up with ever-faster mass storage.
