Hi all. Is it possible to overdub on a dual cassette deck, using the line-in? I just wanted to record voice on top of previously recorded material. Advice is greatly appreciated!
Only way I can imagine that working is to remove the wires from the erase head. You could wire in a mini-switch so you could turn the erase head on or off.
Otherwise, I can not think of any way to do what you want to do, with access to only one deck, regardless of it having one or two cassettes in it.
The line in is turned off when you are dubbing from one cassette to the other. So there is really no way to get in there unless you were to modify the tape decks electronics, somehow. You could go through a mixer with a cassette deck and the live signal to a second tape deck.
Instead of letting the machine start both tapes at once......start tape one, hit record on tape two. This was how I used to multitrack back in the day. I've done it hundreds of times, still have that deck too, just not in front of me right now.
So in other words, indicate "syncro start" recording, but don't start the decks together? I thought that was automatic for both decks to start in sync, but I guess not?
Well, maybe not. I'm looking at my old JVC deck. It has a 1/4 jack on the front with a level control, and was specifically designed to overdub. As I recall, that's why I picked it from the herd. I know the procedure was, set deck two to record and hit pause, then start deck 1 playing, then release pause on deck two. It may not work with line in sources, sorry, my bad.
