scarr3d
hi all,
a friend and i are rebuilding our studio in a 23' x 30' space. this is my first time doing this, so i have a lot of questions that i couldn't find answers for.
the space will be divided up into a live room, control room, and an isolation room. we're doing the framing for the main wall currently with 2 x 4 studs.
here's the plan for the walls, so far: in between the studs, use spray cellulose to fill the gaps, affix Auralex Sheetblock to the studs, affix the drywall to the Sheetblok, lay down another sheet of drywall on top of the other with caulk.
my questions are:
what thickness of drywall should we use?
is spray cellulose the way to go for the insulation?
should we use acoustic caulk, or just silicone caulk? we need to screw in anything?
how do we do the seams? i've heard things about tape and mud...
are resilient channels necessary? if so, how?
what is the best way to affix the Sheetblok to the studs?
in the live room we'll have a drum kit, bass amp, and 2 Marshall stacks. we're trying to keep out sounds from the warehouse. but more importantly, keep it quiet enough for people to work downstairs. i'm sure i'll have more questions as the work progresses. i'll have to post separate threads for the wiring and door questions. =]
thanks for reading!
my questions are:
thanks for reading!
