*Drum Triggering. Wha..?*
  • Thread starter Thread starter janthemetal
J
janthemetal
Hi,
I guess this comes under MIDI, but we shall see.
My question is, how do I get a Piezoelectric transducer I have taped onto a kick drum to trigger a drum sample on a virtual instrument? If at all possible, can this be done without the use of MIDI, as I currently own the grand total of zero pieces of MIDI kit (i know, i know...)? I'm using Boxsounds Replacer plug-in.
I have the PET running through an unbalanced, low-Z cable with a jack on the end, going into my Mackie Onyx desk and onwards to REAPER.
Thanks in advance
You need to get an impulse to midi plugin. Drumagog will do this, but there might be more out there.
The other thing you can do is just record a drum hit from the VI and load it into the Boxsounds replacer.
I use the Alesis Trigger IO. Each of its 10 inputs handles 2 triggers. I'm sticking transducers in 20 old Casio drum pads to make them velocity sensitive and running them into the Trigger IO for MIDI conversion and instrument mapping.
