Drum submixes - some advice please
  • Thread starter Thread starter Dr. Jeep
thanks
Thanks Jeep and Tobias. I think I understand a little better. I have not quite gotten that far yet into bussing and submixing, and I am a "green" studio engineer. But I have a great tutorial book and I am learning more everyday :rolleyes:
Dr. Jeep said:
Are submixes the way to go?
In my experience, to be avoided if possible, but not uncommon to do so.
The mere act of "bouncing" is submixing. As much today as in the older, it still has to be done from time to time. So you don't need to buy more CPU power or anything like that, it's simply just mixing with a "vintage" head.
With practice, you can do just about the same thing with 90 tracks that you can do with 24.
As advised, I would do it with caution and extremely compensative. A drum set that sounds good alone may lose it's power simply by adding on additional tracks that mask the vital frequencies that where responsible for its impact in the first place.
A popular method to try is stem mixing. Just like in movie sound mixing, you create "stems" or groups of like audio, then mix them and process them as a bounced group.
However, you can already see how limiting and time consuming it is if you have to go back and remix a stem. Or if you're not comfortable with it. Or even worse, if you erase the original tracks thinking it was final (which nothing is EVER final in audio).
So in Pro Tools, I would simply create a drum stem (with it's FX) and then make the original tracks inactive.
You can create a stereo track, assign it's buss input to whatever you choose, then route your drum FX and track outputs to that buss. Just whatever you do, avoid any type of buss processing like compression, limiting, etc. Buss compression in DAWs seems to be really weak for whatever programming limitations with the plug ins and the software itself. Unless you're dealing with something like the Impact Buss Compression Plug-In (TDM).
Of course always keeping in mind it's position and making sure than any extensions or subtractions that are made to the song are checked to inactive tracks.
Damn, you are pretty when you are giving good advice.
Actually, I arrived at this truth after making some mistakes. I am Mr. Stems now - you are right, nothing is ever final and that was a big concern. When you deactivate the track and its plugz - it doesn't draw any CPU, right?
What about additional submaster drum tracks that get squished and thrown under the main drum submix? Do those add some extra punch?
Oh they can...just have to watch out for phasing problems.
So they can phase out the source? Another question - I used some tape and tube saturation plugins on my drums (its a drum machine - I am going for a more retro sound) and they are good but a little "thick" for lack of a better word. Is this because I have warmed/compressed them too much? Thick is better than thin - but the snare in particular is a bit flabby at times - especially during the flam parts. AND - this is after a good EQ'ing...
They aren't bad - just less defined. Should I back of the "warmth"?
C
Replies
23
Views
4K
Old Music Guy
Old Music Guy
cmharwood89
Replies
3
Views
2K
cmharwood89
cmharwood89
B
Replies
11
Views
1K
BaronEstelle
B
Rampant Colt
Replies
77
Views
6K
Maya Clars
Maya Clars
