dobro
Is there drum software that will register drum hits so that you can map, for example, synth stuff onto the hits?
Um, i might be barking up the wrong tree here, but do you mean a software that will map an audio recording of a drum beat to midi data?
I know there is software that will do that, drumagog for example, and i think ableton and some other DAWs including Reaper have that function natively.
Sorry to be vague, but i've never used it, and from what i've heard it can be a bit imprecise sometimes. You could always just transcribe the track to midi manually which is what i would do, but that could take some time for complex rhythms.
Otherwise what Chili said makes sense to me too, particularly if you have external devices.
But if you are drunk, you probably don't care anyway and i can't criticise you for that![]()
lol you guys need to speak better noob.
Yes there is drum programs that will play using a keyboard with midi outputs.
No there is nothing that will play from recorded synthesizer audio because synth audio has no hits to detect.
Yes there is software that will trigger drum sounds from recorded audio, but it has to have enough of a transient to detect. Sausage audio will not work.
Hold on, you could technically take a MIDI drum track and route it to a Keyboard and then the analog back in. Probably would sound like poo, but it would work. Better idea if this were the case it take the hits, look at where they are being triggered and determine what note you want to play.
But drum hits are just MIDI notes mapped to trigger a sound. Plus in Ableton Impulse is exactly what this does. One song I did I took a drum track and mapped it to trigger sound effects. Bomb explosion for Kick, Machine Gun for Snare, and Swords for Hi Hat.
Slate Trigger....
I don't have Ableton. Do you like it?
It's called Drumagog.I'm asking if there's software which will register drums hits in a way so that you have a track of drum hit mappings which will then allow you to drop samples into the track so that the samples are triggered by the drum hit mappings.
Look, indulge me. I'm drunk. But it's a great idea. If such a software existed, I could map synth sounds or *anything* onto the drum hits in a track. It'd be awesome.
If you are playing the synth, you can just midi it, but if you are trying to trigger drums sounds from audio, Drumagog is what you need.
