N
noiseordinance
Hi there. I'm using real drum kit samples and have all the drums broken out into separate tracks. I'm curious if anyone has any advice on which drums they recommend reverb on, if not all tracks to varying degrees? I imagine the biggest one is reverb on the snare. I also imagine that reverb should be subtle, though that is dependent upon the type of music. In my case, I record anything from Radiohead (which I figure has longer tails) to metal (which probably has shorter tails). At any rate, I'm not sure if ya'll recommend reverb on ALL tracks, or if it's typically limited to just kick / snare....?
Thanks!
Thanks!
