Hi everyone. I am running Shure 57s from snare and toms,
Shure Beta 52 on kick, and two AT2020s as overheads into a PreSonus 1818 VSL, into an HP Pavilion laptop (will post specifics on the laptop later if required). I am using
StudioOne Professional as DAW. Drums are
Pearl Session Custom Maple. Paiste cymbals. Remo heads. Vic Firth sticks, wood tip, 7A American hickory. Room is basement with carpet floor, painted walls and ceilings. Low ceilings though, not much I can do about that.
I run separate compressors on the kick and snare, pan the overheads hard left/right, rack tom 15% left, floor tom 25% right, then run everything to a bus, which gets a bit more compression and EQ.
Also, I pull down 80hz (+/-10hz) about 1-2db on the bass guitar track to make a little more room for the kick drum.
The doubling of compressors (first on
the tracks and then on the entire bus) helps to pop the drums out in my mixes without sticking way out there. I am OK with it but sometimes I feel like there is too much compression. It also creates
a natural reverb, almost garage sounding quality, I assume all that compression is pulling the room dynamics out of the dead space.
How about you all? How do you mix your drum tracks to get them to pop in the mix without sticking out awkwardly in the mix? I want to hear the beat, the kick and the snare specifically, without it being unblended. Is the double compression the best way to go about doing this or is there something else I can be trying? I have tried NOT bussing my drum tracks and they really seem to get lost or I lose particular pieces of the kit as a whole. Thanks for considering my mixing technique described above (after reading the gear I am using). Please let me know if what I'm doing is the best way to go about it or if you have alternative mixing techniques.
