T
tojo
I have behringer c-2s!! They work pretty well. I paid my friend for his used pair - only $30. We miced an entire kit with them and the results were pretty good.
Yeah you get more bleed, but does this really matter if you're going to be mixing all the sounds together? Good placement with ensure no phase issues and you get a much crisper sounding snare. I love it!condensers on snare? Maybe... I don't see why not though - except for bleed from the other drums... I'll give it a try with my at 2020
and yeah actually buying a kit is a decent idea, although I myself am just going to stick with a 58 on kick and a soon to be 57 on snare + 2 over heads
They're generally more sensitive(especially high frequencies), so they do a little more, even cardioid, but it's not a bad thing.A condenser doesn't pick up any more bleed than a dynamic. That depends on the pickup pattern of the mic.
They're generally more sensitive, so they do a little more, even cardioid, but it's not a bad thing.
Do you like condensers on snare?
what if i you put it in front of a kick?
I would use the at 2020 because I don't have a 57 and I won't for another month and a bit. I don't see what's the big deal with always using a 57 on a snare. I've had unreasonably good luck micing things with the limited amount of mics I have (3 - 2 of which are a matched pair)
Any mic "will do" in a kick. But if you want it to sound good, then there are about 100 better options.
Me too, but if you have a condenser that can handle a high dB level, then there's no problem(apart from maybe hitting the mic, but a good drummer shouldn't do that).Nope. That shit worries me. My snare is loud and I hit it hard.
I'd use two of the same microphone for overhead. The at2020 has a dB limit of 144dB at 1kHz(but lower frequencies might damage it at lower levels), so there shouldn't be a problem as far as loudness is concerned. But just make should you don't hit the mic. I use a cheap condenser on snare, the SC300 from thomann.de, just so i don't have to worry so much.I have an at2020 which is supposedly a MDC
would it be a bad idea to put on snare? or even kick should I have to wait to get a kick microphone... I'm making do with with what I have. I also have a matched pair of SDC's called the behringer c-2s which I would use for overhead. Could one do snare and then the other as an overhead along with the at2020 as an overhead... I'm just trying to make use of what i've got in the best way.
What kick mic do you use? I really like the drum sound you get on your tracks.
