Simman
amonte said:Simman, you sold me. Those drums sound GREAT!
Does DFH allow you send drums to seperate channels? In other words, can you isolate the snare to one track so that you can add eq/compression/etc. through VST plugins?
Yes you can.
 Since I don't mix "in the box" and use all rack hardware, here is a brief exlpanation of the process I use.
DFH C&V uses a sequencer. Why they didn't make this a stand alone product (similar to DFH2), I can't understand; especially, since it is capable of supporting "live" gigs.
Nonetheless, I use DFH C&V in Sonar Producer 4 and route the individual drums out of a Delta 1010. This gives me 8 outputs that get tracked into an HD-24. Since I only have 8 outs, I also record the MIDI out of the TD-8 so I can play back and record the "room" (ambience) mics.
10 drum tracks into my HD-24
Delta 1010 outs to HD-24
Ch1 - Kick
Ch2 - Snare top
Ch3 - Snare bottom
Ch4 - hihats
Ch5 & 6 Toms
Ch 7 & 8 Overheads
MIDI play back & record Ch 9 & 10 ambience
Once everthing is tracked, the respective tracks are sent into my mixer (Ghost) to be mixed with the rest of the instruments. Since the DFH samples themselves have no processing on them, you may need to EQ, compress, and put effects on the drums during the normal mixing process.
The best part is this all works fairly seemlessly and produces outstanding results.
