Driver installation help
  • Thread starter Thread starter riccol
R
riccol
O.K. I'm embarassed.
Had a audiophile 24/96 for a few years and happy with it. Been rock solid so it has been a while since I downloaded and installed any new drivers
But now installing one on a new computer.
But need help remembering the simple procedure on how to install downloaded drivers on xp.
Any help appreciated.
It's been awhile for me, but lets see if I can rack (errr wreck?) my brain...
You download a zip file from the website. You unzip the files in some temp directory (or somewhere you can remember such as My Documents/delta_drivers)
Then you pop the card in the new PC and boot up. The New Hardware Wizard should pop-up. Don't have it automatically search for drivers, select the option for "I will specify the location." Then navigate to the directory where you unzipped the driver files. Select the *.inf file and continue on. You should be able to ignore the "Unsigned Driver" warning.
Hope that helps!
PS - I noticed you live in Nazareth. I went to Lafayette College some years ago and went to Naz often (visited the Martin factory a bunch of times). Is Jack Creek still off of Airport Road? Me and my wife's first date was at the Red Robin by the movies/Wal-Mart/etc...
Or...
You can download the driver.
Double Click on it.
It will install.
Then hook up your device and click next.
6
OK, maybe they've added a nice installer since I last installed my Delta back in 2003.
Listen to sixways!
Maybe not Gordone, but that's how my M-Audio Firewire 410 works and my Radium 49 key controller.
Should work though.
6
Ya the 2496 driver download gives you an .exe rather than an actual driver file, which makes it easy but I had a hell of a time trying to update with it - the only way to extract the file was to run the setup and then it wasn't overwriting properly.... I finally got it to work after spending an hour trying to locate old drivers and delete all traces of them.... urg....
For a fresh install though it should work well :)
