Drawing for adding control room into live room: Better/worse/same? Begging for ideas
  • Thread starter Thread starter tubedude
tubedude
tubedude
Active member
Its not much bigger than the room I was going to use but probably shaped a little better... is this a decent size? Should I go bigger and shrink the live/drum room down? I'll go ahead and use the previous room I was going to use as a control room as the utility room that it was intended to be and as an iso room.
If you guys have better ideas or layouts feel free to post or email me a drawing... lets just say the room is 20x20, cause thats real close to the dimensions. Keep in mind that the ceilings are 18 feet, though I wont go that high in the control room, so whatever layout ideas you might have for the control room then give me some wall treatment ideas to go along with it.
If I make those 5 ft walls 6 footers, that makes an extra foot behind the mix station (on the window wall), or I could possibly come down 11 feet on both sides... hell I dunno... what would YOU do?
CLICK HERE FOR DRAWING
