Atkron205
Member
Hey all,
I have a DP-32 with outboard compressors. one limitation of the DP-32 is if you use the internal comps you can only apply it on the way in. I want the ability to add compression during mixdown. I run everything through a console (SX4882) first, then route the 8 sub groups to the 8 inputs on the DP. My idea is to setup one of my comps on on the FX 2 send on the DP, then I can route the comp return back to a track on the DP. That way I will have the dry and comp vocal to compare and have the option to redo it if I need to. Anyone have a better idea? I know, the best option would be mixdown on a DAW but I do not have one at the moment. Thanks!
