andrushkiwt
I like using this on choruses, but I'm noticing some issues the more I do it. For one, sometimes the two takes seem to "jump" into complete harmony and the combination of the two is louder, almost piercing. Hard to explain the sound, but it's almost as if they are completely in pitch with one another...so that cumulative effect starts to resonate. It's not the entire line, but usually a loud, held word. I use Melodyne to separate the pitch slightly.
What is your chain/setup for processing double takes? Anything in particular that works well for you? Here's mine:
- harder compression on second take
- panning is both centered, sometimes L5 R5, or in that area depending on song.
- EQ is slightly different. second take has highs rolled off.
- second take is 8 or so db's quieter, usually
What works for you?
What works for you?
