B
Bdrum
OKAY, IF YOU WERE TO HAVE TWO (MATCHED?) PAIR OF BASS DRUM MICS.... WHAT WOULD THEY BE?
Now do they really have to be matched?
Can you Imagine two matched Bdrums?Farview said:I use either AKG D112s or Shure Beta 52s. They don't have to be matched, but they should be the same mic. Unless the drummer has a very expensive kit, the bass drums won't be matched.
DW kits can be timber matched, I'm assuming that other high end drum companies offer the same.Bdrum said:Can you Imagine two matched Bdrums?![]()
They usually can achieve that by cutting one long shell in half. (You can order a single shell up to 48" long, and then cut it into segements)Bdrum said:Can you Imagine two matched Bdrums?![]()
Bdrum said:My original kit has two bass drums that the serial #s are real close.
Maybe I'll take up 4 channels, Two triggers and two mics.![]()
