HangDawg
bUnGhOlIo
So how much difference in level can there be before there would be problems? I did a live show and there is clearly a difference. But if I adjust the balance, it seems to lose some of it's imaging.
HangDawg said:So how much difference in level can there be before there would be problems? I did a live show and there is clearly a difference. But if I adjust the balance, it seems to lose some of it's imaging.
HangDawg said:It sounds pretty good actually but it's about 2db louder in the right channel is all. Do you think I should even bother?
masteringhouse said:Can you give a reason why one side is louder than the other? If it was an error in setting the levels properly, then I would fix it, if it's because one side of the stage was louder than the other then leave it alone otherwise the stereo field will shift.
When recording in stereo it's always a good idea to set up the levels with a reference tone so that you know they are equal. You also want to space the mics so that they are equidistant from the source, not only for level reasons, but also for proper phase. This is also the reason many used a matched pair of mics for stereo recording, so that the characteristics of the mics are as close as possible.
BTW are you really see a 2 Db RMS difference or is it peak level? I would be less concerned with peak, 2 Db RMS is significant.
HangDawg said:Keep in mind that this was in a nightclub with 2 rock bands and I've never done this before.
It was louder because it was set up for the 2nd band which has 2 guitar players ( 1 on either side) . So when the first band played (1 guitar) it was louder on the right. This is truly how it sounded though.
And yes, it's 2db RMS.
masteringhouse said:Stay with the truth then.
I usually don't do this, but you may want to try unlinking a stereo compressor over the mix to help even them out a bit. The bad thing about doing this is that the center may shift slightly. If the release time is on the longer side it may not be as noticable though.
Let me know how this works for you.
