James HE said:
you can resample in Vegas. I think it is as simple as "mixing to new track" with a different bit depth.
Ed, is it "wrong" to resample and convert to 16bit at the same time with a program like Wavelab?
-jhe
No, as long as the dithering takes place AFTER the resampling. I have been using
the Waves L1 Ultramaximizer dithering scheme instead of the Wavelab scheme, and the L1 is last in line anyway, as it should be in any mastering process.
Anyway, if you do use
the Wavelab dithering scheme, it will be after the resampling, so you are okay.
By the way, although very subtle, the L1's dithering scheme seems to have a richer sound then Wavelab's does.
Also, when you apply dithering, you are not actually reducing the bit depth yet....You are just adding dithering noise at the end bit depth you are going to. So, while you may dither a 24 bit file with a 16 bit dithering, you still wind up with a relatively "noisey" 24 bit file. You then hopefully have a smart Save As function in your editor that will allow you to pick a new bit depth (Wavelab does this if you pick the Convert in Save As.
You could also just apply the dithering, keep the file at 24 bits and open it in ANY editor that will allow you to reduce the bit depth in Save As. Even Goldwave will do this. Basically, you are just truncating the file, but since you already added noise at -93dB ((I believe that is the level dithering is added because dithering makes you lose 3dB of sound to noise ratio) you will not per se be losing anything. Just noise that is below the 16 bit converters s/n ratio.
Anyway, there you go.
Ed
Ed
