Nick The Man
does anyone mic the bottom of the snare if so what mic should i use
Same same here.Chibi Nappa said:Sometimes... but I find micing the side of the snare to be much more useful. An SM57 should be fine. Put the mic near one of the small holes in the snare shell, but angle it enough so the air doesn't make the mic pop. I find this is a better sound than the underside of the snare.
A funny side. At a local two thousand-seat gig, when the name band came up, even as the mc did his intro I thought for sure, blown HF driver. The band played, more torn aluminum sound - a nice hot bottom snare mic.Son of Mixerman said:When was the last time someone stuck their head under snare?
SoMm
Son of Mixerman said:I never mic the bottom.
When was the last time you stuck your ear an inch away from the top of a snare?
Never had much luck mic'ing the snare bottom myself, although the snare side thing I've yet to try out.
robin watson said:When was the last time you stuck your ear an inch away from the top of a snare?
franksquid said:Using a 4 mic setup(XY overheads, snare, kick), I use a SM57 or M88 on the bottom with reverb. Sounds great to my ears. YMMV.![]()
EleKtriKaz said:You're only micing the bottom? If you're doing top and bottom that would be a 5 mic setup: x, y, kick, top, bottom.
Nick The Man said:does anyone mic the bottom of the snare if so what mic should i use
