H
HB1978
I exported a midi file from Fruity Loops. When I load it into the Korg Triton keyboard in 'song play' mode it doesn't play. Can someone help me?
In the 'Song Play' mode/screen, Page 0, there is the word 'file' just below the top left corner of the screen. Next to it is the actual file name (this part actually points to the file on disk). And to the right of that is the name of the file (I know it sounds confusing but that's how the Triton is).
In my situation the file name to the right is blank, but to the left the actual filename is there (the name of the file should be on the left and right). When I press play the Triton actually freezes up and then i have to turn power off and back on to reset it. But peep this, when i load a midi file from protools it plays and everything works.
This is how i've been doing it: I make a song in protools via midi, playing the Triton. I save the midi file and load it in the Triton. And it plays.
On the other hand I made a song in fruity loops using all the fruity loops instruments. I save the file as midi and load it up in the triton and it doesn't play.
I have a Triton.. however.. I have abandoned the use of the on board sequencing all together.. you're better off running midi cables back to the triton.. and then just sequence the midi in PT or FL whatever.. you can use the sequencer within the daw to control the triton like a synth module, though don't ask me how to set the korg up to support this... the korg is not at all user friendly.. everything is convoluded and doesn't really flow well..
I personally prefer just recording the audio by playing it.. with elastic audio I have found this is the fastest way for me.. Keeps me creative..
I know this wasn't much help for what you're trying to do.. I would look more into setting it up as a synth module via midi though and I think you'll like that a lot more than importing the midi.
That's the setup I am trying currently to set up. I have it set up now to where i can play the triton with either fl or pt. I just have to work out some problems with patches and banks and channels, etc. However, if I create a midi file in pt to play the triton, how can i play the midi file and record the audio at the same time? Wouldn't i have to load the midi file into the triton, play it, and then record it to pt? Is there a better way i can do it?
