does a direct box work with basses?
  • Thread starter Thread starter fleabass
F
fleabass
Hi, I want to record my bass directly to my computer, but the sound is awfull, I've heard this is because the bass signal is unbalanced. A direct box solves this problem? or should I buy a device like protools or m-audio?
thanks!!!
a proper di box will accept both bass and guitar. it has a input for the bass and an xlr output jack. connect the xlr out to mic in of your mixer and gradually bring up a fader. they can be had around 50 bucks.
or you could use an old bass rockman, and there are lots of other devices.
just google for bass direct box.
If you're just plugging into a normal computer sound card, that's the reason why it doesn't sound as good as you'd like. Low-end preamps and converters. The reason for a balanced signal is largely noise - unbalanced lines (Such as an instrument cable) pick up a lot of noise over long runs, and balanced signals cancel much of the noise out.
Also, a reason for a direct box is that the output from an electric instrument like a bass or guitar is a high impedence source, and a direct box will convert it to a low impedence level, basically a mic level. So you can then plug it into a mixer or whatnot, and it will basically be the same level signal as a mic would be.
If you're just plugging into a stock sound card, a DI box isn't what you want to improve sound, you'll need a sound card or interface more dedicated to recording (THere's pci stuff such as the m-audio audiophile 2496 [which you will need a preamp such as the audiobuddy or dmp3 for, as it's just line level inputs], and there's all sorts of firewire, usb [although many people are wary of usb as a means of audio interface.... I use a usb interface with no problems, but many have had bad luck with them])
