Do you know how to fit 244 control belt ??
  • Thread starter Thread starter Stuartm
Stuartm
I have just got new belts for my 244 Tascam portastudio as I use it for quick records of ideas. The capstan belt is straight forward but the control belt - the thick one - looks as though you have to dismantle half the macine to get it on. Is there a trick to this?? or can anyone giude me to a site with intstructions.
Any help appreciated
stu :confused:
Another problem
OK. I've figured out how to get all belts on - was actually the capstan belt causing previous problem - but now problem is that controls are out of sync. Have figured out that pot controls motion of control drive wheel but all is out of sync - does anyone no how to get these back in sync without having to remove transport mechanism. If no one can help I'll just have to buy service manual.
Stu :confused:
Forgive me, 'cause it's been a while, but...
I think you have to rotate the head/load mechanism 180 degrees, and you'll be okay. Also, make absolutely sure that the connectors are on correctly. A flipped over or backward connector might cause the same symptom. Bottom line is that you have to play with it until you get it back on correctly.;)
