dmp3/mbox question
  • Thread starter Thread starter second skin
second skin
BEAT IT!
i just got a dmp3 to use into the 3rd and 4th inputs of my mbox 2 pro. the mbox has a global knob for input 3 and 4 to keep from clipping the A/D. i'm having a problem where even with this knob all the way down and the gain on the dmp3 all the way down i'm still getting clipping.
i have a feeling it may have to do with a mismatch somewhere. thought i might seek some advice from you folks on what direction i should take. my first instinct is to get a pad to go between the two but i don't want to do that if it's and impedance problem or something.
here's specs for both pieces of gear.
mbox 2 pro
Aux Line Inputs 3/4
Headphone Outputs
Connector: Two balanced 1/4" jacks
Frequency Response: +/- 0.1 dB
Dynamic Range: 104 dB / 106 dB A-weighted
THD + N: 0.001% (-100 dB)
Input Sensitivity: 10 dBu minimum gain, -10 dBu maximum gain
Input Impedance: 16 kOhm
DMP3
All specs taken at minimum gain unless otherwise stated:
frequency response: 20Hz – 80kHz, +/-0.5dB @ max gain
SNR: -120dB, A-weighted, 20Hz to 20kHz
THD+N: 0.00035% (-109dB), 20Hz to 20kHz, @ +13.6dBu input
max input: +14.6dBu
max output: +27.5dBu
input impedance: 3k Ohms balanced
EIN: -128dBm @ 600 Ohms, max gain
gain range: 13.5dB to 46.5dB, low gain range
39.5dB to 72.5dB, high gain range
low-cut filter: -3dB @ 72Hz (18dB/Octave)
