Check in control panel to see if anything else is set for the same DMA channel.
Control Panel / System / Device Manager / View by Connection if you are using Win98
I don't know if this would uncheck the DMA box - probably not - but make sure you have an ata66 cable for running udma66 or ata100 cable for udma100. Also, make sure your mobo supports it. Hope that helped.
