DM-24 and MIDI control of Cubase
  • Thread starter Thread starter mastahnke
mastahnke
mastahnke
Linux Man...
I used to have this working, but today I can't get it.
I have midi from Cubase to the DM-24, faders fly, MTC shows up etc.
I have nothing from the DM-24 to cubase. I checked the MIDI cable. I can't seem to get it to output any midi messages. Im sure I changed a channel or something, but the WONDERFUL (ha) documentation from Tascam's website doesn't say much about settings that are default.
Any help?
MIKE
I dont hook my DM24 up midi but I know that three of the places you should look to see what the settings are set up like are
(1) Shift key then option button check Sync/TC and check all your sync sources.
(2) The midi MTC button. are your settings under machine control setup, the way they were??
(3) shift key then the digital button under clock,
your problem is most likely in one of those areas if its not your cables. Who or what got you setup when it was working???
I had it working before. (I set that up).
Im not at the mixer right now, but I will pull up those menus and let you konw. I know that the Sync/TC is setup correctly.
I will check the Midi MTC stuff.
