I just banged one out between sessions. See sample1 at the bottom of this page:
http://www.masteringhouse.com/masteringclinic/
My intent was to retain as much power as I could from the original, but clean up some of the issues with the bottom end and the synth and make the snare and guitars stand out more. The vocal is a bit mid oriented, but I kinda like it that way. It reminds me of a Floyd vocal sound.
The main technique that I used for this was M/S EQ and compression. Essentially I ran busses from Pro Tools to create an M and S send. Then added a 2.5 db cut at 128Hz Q=1 and a multi-band comp with a low shelf at 100 Hz down to cut back on some of the kick and synth on the M channel. The S channel was untouched. I also reduced the M slightly to try to widen the sound field a bit.
Let me know what you guys think of the above. There were other EQs/comps used as well. I'll give you the details on those if you guys like this, if not then it doesn't matter and they will change anyway.
