DIY Fender '51, help choosing the pickups.
  • Thread starter Thread starter GuitarDR
G
GuitarDR
I am intending to make myself something similar to the Fender Pawnshop '51 using off the shelf parts. A few weeks ago I tried one and I really liked it but thought I didn't want to spend £575 for one... (I did a review of it here on my site) Also the scratchplate/pickguard is a bit ugly. I've already bought the body, neck and bridge that will be used. I've found a wiring schematic for two pickups with one volume and one blend control, just like the Fender '51, so I'm all set with that.
The Fender version has a Texas Special neck pickup and an Enforcer humbucker. Here's the crunch - I don't want to fork out for those pickups, I'd like to spend £50 or less for the pair! The other thing I'm thinking about is while the '51 has two black exposed coil pickups I'd like mine in shiny chrome, just because I like that kind of thing...:) This means for the neck pickup I'm going to choose a Tele neck pickup and for the bridge pickup there's lots of PAF style humbuckers to choose in Chrome. What I need help with is choosing two pickups that will complement each other and sound nice blended. I hope someone has this kind of experience. Obviously for the £50 budget I've been looking at brands such as Wilkinson, Artec and IronGear but there might be others I am unaware of. If a few quid would make an awesome difference then I'd probably up the budget... Thanks in advance for your replies. Mark
I bought one of the squier 51's a few years ago when they were available. After a little work it's a pretty nice guitar. I wound my own pickups for it. 8.5k AlNiCo5 humbucker, and a A3 strat pickup wound to 6.5k at the neck. They balance really well. A vintage spec PAF type, and a proper tele neck pickup should sit well together. I didn't care for the '51 style pickguard either. I made a custom clear one for mine. I also upgraded the tuners, electronics, drilled the bridge, and strung it through the body. The Squier 51's were a neat idea. I wasn't surprised when the Fender version hit the shelves a few years later.
Thanks, John for the considered reply. I had a hunch a lower power vintage style humbucker would be the best for balance, thanks for the details of the resistances etc too. Winding my own is a little bit too hands-on for my plans, there's so many other things need doing on a new build! You have improved your '51 a lot. It's good to see it wasn't routed behind the pickguard in the factory. One thing the guy at the shop asked me about the blend pot was if I wanted it to be 100/100% in the centre notch or 70/70. I could experiment, but can anybody confirm the blend pot type? Cheers, Mark
y/w Mark, These are fun guitars, I'm anxious to see yours when it's complete.
I was happy that there was no rout behind the pickguard. I had originally planned to put a black guard on it. I think this looks much better. When I bought it they were quite popular as a platform for modification. I was taking on a new found interest in pickup winding, and the '51 was just what I needed to get my feet wet.
I chose to overwind the pickups a little because I didn't want them to be too bright. With no tone pot you have to get it right. Experiment with your tone capacitors! It really makes a difference. I'm using a .033uf polyester cap, and a 500k volume pot in mine. The highs roll off differently with the higher value volume pots.
That's not a blend pot. That's a three way rotary switch. There's also a push/pull on the volume that split's the humbucker. Your five way switching options are as follows; neck only, neck + full h/b, neck + split h/b, bridge only full h/b, bridge only split h/b.
Thanks for that extra info about the capacitors. They're cheap so I can test out various values.
I've been waiting nearly a month for the body and neck to be made and sent to me... When I've finished the guitar to my satisfaction I will post up a picture, I'd expect that to be in August at the current rate of speed! I'm really looking forward to getting started though. It won't look a lot like the '51 but will be sharing the electronics/pickup config mainly.
I've dusted off the old stock pickups that came with my '05 tobacco-burst '51, and put different magnets underneath them. A3 Firebird magnets under the single (more like a P-90 i suppose than a Fender pup). A2 bar under the humbucker. I'll let you know what I discover. It's being wired up so that I can present a completed mod to the forum!
