scottmd06
I'm planning to remove the trigger pads from an old Yamaha DD-50 and install 1/8 or 1/4 jacks for trigger input, and use the MIDI out from the DD-50 to input into my DAW. The DD-50 would basically be the "brain" of the drum kit and act as a MIDI controller in which I would assign various drumkit sounds through my DAW. I may be able to find some used drum pads pretty cheap, or build my own with some piezos, plywood, and rubber padding - build the rack from pvc? Does this plan sound feasible to anyone else?
