T
travelin travis
Tim Brown said:Try sandwiching the trigger Assembly in several layers of foam.
sounds like a good idea.
Tim Brown said:Okay,
how did you mount the triggers to the board?
Are the can lids mounted directly to the board? If so, that's going to cause all sorts of crosstalk and false triggering. You have the mount the metal pieces on foam, so that they float.
If you attached the directly to the wood - you'll have to rebuild it.
What you need to do, is use a hot glue gun and glue a foam "ring" (just a foam strip glued around the edge of the metal) between the wood and the metal to act as an insulator/isolation so that they strikes don't pass from one pad to the next.
I would have made fewer pads on the unit, and made them bigger.
Tim
TravisinFlorida said:.......just heard your tune in the mp3 clinic. my apologies about what i said about you not having much experience around a kit. i guess i just heard the above clip out of context with the rest of the music. it makes alot more sense going along with the guitars. i stick my foot in my mouth sometimes. you'll have to forgive me.
Tim Brown said:Now, if you guys want to try this, I've got a little better method.
Go to your local DIY hardware supply store, and look in the are where they have gutters. You can get little pieces of sheet metal that are say 4"x6".
Just use a piece of plywood, and make your pads rectangle in shape.
Get some carpet foam pat, and use as your isolator, and glue that to the plywood, glue your refraction plate or whatever you want to call it (the metal plate with the piezo disc glued beneath it to the foam, then glue a mousepad to the top of each plate.
Just remember to drill a hole in the board and feed the wired from the piezo through the hole in the board and foam prior to glueing the foam with the plate down.![]()
Tim
aspiring said:I have just about finished my own set of edrums. It started as a small fill-in electronic project before Christmas. Next thing...I've just about got a whole rig set up! And it's loads of fun to play (never touched drums before in my life!).
Good luck
aspiring
