White_Rabbit
Ok, I wanna build a really small, idiotically simple A/B switch box to switch between keyboard/theremin and Guitar, and I figured with my absolute lack of knowlege to do with these sorts of things, that I could build it using 3 x 6.5mm input sockets and a SPDT switch, hooked up with two of the plugs going in on one side (the "input points) and the 3rd plug on the other side, sort like the picture below, except inside a small container (I have an empty mints container made of metal that is the perfect size). Also, the second "prong" on each of those plugs is the ground, yes? So should I just solder them to the tin or a common point?
Am I missing something here, or will this bare-minimum approach work? Should I be adding some capacitors or something for some reason, such as to level out the voltages or somesuch? Those A/B pedals that Boss and such make surely have more to them than this...?
PS: Sorry if this isn't the right forum, but I figured it sort of applied, and this area gets plenty of hits, which means more chance of someone with some knowledge being albe to help me
