mshilarious
Banned
OK, let's just try this:
Truncated Organ
These are three organ pipes, of increasing pitch and thus decreasing quantity of overtones (due to bandwidth limitation at A/D). Recorded at 24 bit with a KSM44 at 12 inches, not exactly a natural way to record pipe organ--these are mouthblown. There is no way an installed pipe in a pipe organ could produce as noise-free a recording (blower noise, room noise)--and this recording isn't a pure series of sine waves, because moving air produces noise. Then I applied a fade to each pipe, then truncated to 16 bit.
Anyway. Please be aware that especially the last pipe will be very, very painful to listen to on headphones at a calibrated monitoring level. You'll basically be feeding an 85dBSPL 3kHz sine wave directly into your brain.
Now, can I measure QD on any of these samples? Yes, I can, the last second of the fade of the last pipe shows some QD at -140dBFS. You don''t need young ears to hear it, the QD is not at a high pitch. But I did need to increase gain +14dB above my reference point to hear it, that would make the beginning of that pipe nearly 100dBSPL, which hurts real bad. On monitors, I believe it would be impossible to hear without a stupid amount of gain above reference level, because of the masking effects of room noise--you would probably need to set your monitors to 120dBSPL.
My conclusion--if you are recording something like a solo piccolo-ist who isn't breathy (or the aforementioned pure synth stuff), consider dither. Otherwise, get back to selecting that bus compressor . . .
Truncated Organ
) of instances that keeps me from saying that 16-bit dither is completely inaudible.
