H
HrsofObscurity
I need some micing tips for distorted guitar so it sounds clearer instead of muddy. Also can u playback track while recording others?
thnx
thnx
you can try backing the mic away from the speaker slightly. are you using a pre-amp on the mic? you can tweak the input/output gain with that so there's no distortion. also - you'll probably want a pair of good headphones to listen to tracks while you're recording. otherwise, the mic will pick up the other tracks through your monitors (unless you're recording in a seperate room from monitoring).HrsofObscurity said:I need some micing tips for distorted guitar so it sounds clearer instead of muddy. Also can u playback track while recording others?
thnx
