I'm one who thinks EQ is 50% of your sound. A good tube pre-amp and tube power amp are 45% and the rest can be distributed among your FXs. I use a rig comprissed of compressor, Mesa Triaxis, Digi 2101LE multiFX, a couple of other gadgets, and then Mesa 20/20 tube amp feeding a 2x12 Mesa cab.
I've turned myself lately into refining my sound and after distortion EQ is the best way, I believe, to achieve it. While the Triaxis offers quite an assortment of sonic possibilities itself, I think I've already programmed in about 7 to 10 distorted sounds that very well cover all my needs. But from time to time, I still feel I need to fiddle the sound from the Triaxis a bit to make it sound really right where I like it. Is in those moments when I go and play with the multiFX parametric EQ, opening dozens of new other possibilities.
Although trying to match this or that player's sound that you think is great is very challenging as recordings involve many other variables, most probably being introduced at the mixing/mastering studio, I was wondering whether someone could suggest some examples of parametric EQ settings that in your opinion help a heavily distorted metal guitar sound be more focused, tight and right for you to record and later on mix down.
(Footnote: I'm not saturating the sound with gain, drive and/or bass all maxed out at 10 on the Triaxis; just in case)
