Disabling USB
  • Thread starter Thread starter version2
version2
version2
Well, I was trying to disable usb on my Dell, which is only for audio. I can disable the usb hub but when I disable the Universal Host Controller then I can get the machine to boot up. It just hangs out on the startup screen. Anyone ever have any problems like this?
"Physically" disable the USB controller via the BIOS setup.
Slackmaster 2000
Slackmaster 2000
Ah...would if I could. Its not in there.
*sigh*
Thats what you get when you buy supermarket computers!
Build your own next time :) (make sure it AMD)
Find out what Mainboard is in the machine and flash the BIOS with an updated version with usb controller settings (if there is one?)
Be carfull doing so make sure you understand the steps inside out!!
I had popping and crackling in my system which seems to have been caused by USB. I disabled the Root Hub, but left the Controller enabled. That fixed the problem for me. It also allows me to use the USB when necessary by simply re-enabling the Root Hub. If you disable in the BIOS you will have to re-boot anytime you want to use USB, and then reboot again to turn it off.
I assume you are disabling due to some problem. Did disabling the hub not fix your problems? If so, it *may* be that USB is not your problem.
I understand that ACPI might be another source for these type of problems - particularly if you are running Win 2000 or XP. Apparently ACPI causes all PCI cards to share the same IRQ. You might try switching to Standard PC mode if any of this sounds like it applies to your case.
No, there were no problems. But, the polling of USB through the bus is pretty considerable. Since I will not ever be using any usb devices I figured it would be best to get rid of it.
ACPI really sucks i think it should be disabled on any computer used for music.
