D
djclueveli
does samplitude not allow direct x plugin automation? because i only see it for vst automation.
Mistral said:I would be very careful using direct x plugins in samplitude, it can cause the program to crash. make backups often if you need to do it. and do not under any circumstances put dx plugs on VST output channels.
Mistral said:sorry, VST(i) Output channels. You know, when routing a midi track through a VST instrument.
I never said all DX plugins caused problems, but some do.. poorly written or not, I would recommend not farting around with it to find out. I stopped using DX in Samp after losing a good half dozen sessions (wouldn't open until I disabled DX in the ini, and even then I lost a good deal of what I had done with the mix because of it)..
The reason not to do it on a VSTi output is that is where it happened the most, it gave some kind of mismatch error because I had used a DX plug on a VST channel, or something to that effect.
